Love the site, just need some advise on my 318is if possible!
Basically my 318is is overheating.
I can drive it for 30 mins and the temp gauge will sit below half. Then it will slowly creep to between half way and 3/4 and stay in between these two when cruising at 50 - 70 mph.
It will come down to half way if i put on the interior heater.
The viscous fan needs doing but it cant be that thats causing the overheating as the overheating I'm describing happens at cruising speeds - 50 - 70 mpg.
I've changed the thermostat to one that opens at 87 deg C rather than the 92 deg C that was in it. No difference.
From looking at receipts it says that a new rad was put in 3 years ago.
No coolant loss and no mayo in the oil.
It's bled properly.
I have noticed a fair bit of pressure built up in the water hoses I must admit.
Could it be the water pump by any chance?
Help a girl out guys?!?
[img]http://
