Jesus having Diff-iculty
Jesus325iTouring
Frog freak !
Frog freak !
Post Sun Dec 10, 2006 12:16 am
I was wondering whilst driving along today,what diff could I put on my Tourer to lower the RPM?
I'm not fussed about losing off the mark acceleration,but would like to attain better economy on longer runs,I figure the best way would be to change the diff for a lower ratio one,so......
Can I do this?
What different types of diffs are there?
What do the ratios stand for or mean?
Can 5 series ones be modded to fit an E30,when I drove the 5 breaker home it was doing far less RPM than my Tourer does,the 5 has an LSD which I won't be using but i just wondered if other standard ones can be adapted.
Cheers for any suggestions. :D
Jon_Bmw
Dangerous when thinking
Post Sun Dec 10, 2006 12:45 am
You want a lower number Rog basically. I would imagine it has a 3,73 on it but theoretically it could be a 3,91 or a 3,64. The lower the number the better for your purpose. At a guess, 70mph on a 3,64 would be just under 3000rpm. On a 3,91 it would be around 3,600rpm iirc.
Don't think a 5 series diff off an e34 fits but i do stand corrected on that one if proved otherwise. I believe you can get a 3,46 non LSD, but then micras would be annoying you a lot. Right up your street i'm sure, think of the mpg's :cool:
Jesus325iTouring
Frog freak !
Frog freak !
Post Sun Dec 10, 2006 1:01 am
Jon_Bmw wrote:You want a lower number Rog basically. I would imagine it has a 3,73 on it but theoretically it could be a 3,91 or a 3,64. The lower the number the better for your purpose. At a guess, 70mph on a 3,64 would be just under 3000rpm. On a 3,91 it would be around 3,600rpm iirc.
Cheers Jon,
Can cope with Micras annoying me,the tourer generally gets used for long distance trips as my old R5 does the local running about.
To be able to drive at 70mph under 3k would be great :cool:
Time to find a 3.64 diff I reckon to help my MPG,not that i'm tight or anything!
ian332isport
Post Sun Dec 10, 2006 8:16 am
Jon_Bmw wrote:I would imagine it has a 3,73 on it but theoretically it could be a 3,91 or a 3,64.
Tourers usually have a 3.91 fitted.
When I changed from a 3.91 to a 3.64, it knocked 500rpm off at any given speed in top.
I believe you can use E28 5 speed diffs if you change the rear cover and possibly the side flanges. Both very easy to do.
Ian.
Jesus325iTouring
Frog freak !
Frog freak !
Post Sun Dec 10, 2006 9:07 am
Ian.
Thanks Ian,500 rpm less i'm pretty sure would increase my MPG,and make long distances a bit more plaesurable.
How did you find the overall drive changing to a 3.64?
ian332isport
Post Sun Dec 10, 2006 9:11 am
Jesus325iTouring wrote:How did you find the overall drive changing to a 3.64?
Mine was much improved, but it's a little non standard 8)
I did it on mine to make 1st a useable gear, as well as reducing overall revs.
Ian.
mrLEE30
Post Sun Dec 10, 2006 9:22 am
as above and to answer you question about what the numbers stand for they are the ratio of the driving gear to the driven gear. so a 1:1 would turn the driving wheels once per rotation of the prop shaft. 2:1 would turn the wheel once per 2 rotations of the prop shaft and thus the prop shaft would rotate twice the speed to a 1:1 for a fixed wheel rotation speed , and yep you guessed it 3.91:1 is a wheel rotation per 3.91 turns of the prop and 3.64:1 is .......... rotations of the prop per ......... rotation of the wheel (fill in the blanks, half point each answers at the bottom).
thats why lower ratio gives lower rpm for a given speed but you loose mechanical advantage so the engine has to work harder to turn the wheels, hence why you loose acceleration.
hope that helps
3.61 1 half point each!!
Post Sun Dec 10, 2006 10:46 am
Standard 325 saloon diff is want you want. Touring diffs are usually one ratio higher than the corresponding saloon, and autos one ratio higher again.
Changed my wife's touring diff to a saloon one a while back, and it gives that little bit better economy, without affecting acceleration by any great amount.
320Touring
Post Sun Dec 10, 2006 12:53 pm
http://www.unixnerd.demon.co.uk/bmw.html
and scroll down left hand side til you find the gearing calculator :cool:
Jon_Bmw
Post Sun Dec 10, 2006 2:01 pm
Brianmoooore wrote:Standard 325 saloon diff is want you want. Touring diffs are usually one ratio higher than the corresponding saloon, and autos one ratio higher again.
Oh right that explains why my auto saloon had a 3,73 then, as it would have been a 3,64 if it was manual. Looks like i've led you slightly up the garden path with the exact number rog, but the thought was there :)
Jesus325iTouring
Frog freak !
Frog freak !
Post Thu Dec 14, 2006 11:16 pm
Thanks for all the advice chaps,I now feel knowledgable enough to know where to go from here :cool:
Ziggy
Post Thu Dec 14, 2006 11:54 pm
You could even find a 3.45 if you're really after low gearing! :D
Jesus325iTouring
Frog freak !
Frog freak !
Post Fri Dec 15, 2006 12:08 am
Ziggy wrote:You could even find a 3.45 if you're really after low gearing! :D
I went in Scotts Tech1 the other day which has a 3.25,looooooooooong gearing,great for crusing.
But my trouble is I still need to be able to pull my somewhat weighty trailer,If i have a diff to low,it'll just put to much strain on the engine.
I'm going to try a 3.64 soon and see whats thats like and go from there,I suspect a 3.45 will be again getting to low :?
