On the way back from southampton and the diff went. got home but it made a right noise when i backed off the throttle with it in gear.
Anyway, i have a spare one (4.10) off the 318is that i broke. But, when you turn either one of the drive shafts (outputs) it feels quite notchy. is this right because when the prop shaft (input) is turned it feels fine? Please help because i have to fix the car tommorow!
Diff has just gone! Help!!! NEW ONE FITTED NOW 10th dec
bennyboy
16V IS engine!!!
Chris-W
bennyboy
is it worth changing the oil before i put it on? Like i said, it's a 4.10 but dont think it was the original diff on the 318is that i took it from. Just out of interest does anybody know what ratio mine is on my cab? It was an M40 engine in it.
16V IS engine!!!
Demlotcrew
if it has oil and its clean then leave it!
The notchynes it normal.
Andrew
Andrew
gazza
your cab will most probably be a 4.10 as well
bennyboy
Cheers guys. i'll sort it tommorow and have a look at the tag on the diff off my cab. Cheers
16V IS engine!!!
