electric windows dont work
toughyv8
both sides wont budge. i can hear something clicking in the doors but surely both motors havnt gone at the same time?
Give the cut out switch a bit of exersise, or pull it out, take off both terminals and short them together.
toughyv8
i did that i replaced the switch with a 20 amp fuse and still no different
Check to see if there's power at these terminals by connecting a 12V lamp between them and earth, a) with the ignition on and doors closed, and b) with the ignition off and a front door open.
Also should have asked before: Do the switches normally light up, and are they lit up now?
