resetting service lights
toughyv8
Post Fri Dec 08, 2006 9:39 pm
anyone know how to do it
Pal318is
Post Fri Dec 08, 2006 9:43 pm
Pal
Image[img]http://Image
noney82
noney82
too sloww lol
gazza
Post Fri Dec 08, 2006 9:46 pm
or buy the tool mine is a draper one and cost me £12 at gsf saves shorting out the wrong wire and cuts all the fiddling around shoving bits of wire in holes 8O
Pal318is
Pal
SPADGE
Post Fri Dec 08, 2006 9:47 pm
All of the above or be different and take it to BMW for a service winkeye
noney82
i agree gaz
good tool them i got one makes it easy
Pal318is
Post Fri Dec 08, 2006 9:49 pm
tbh...Yes the best way ^
Pal
fuzzy
He who sleeps with "Gingers"
Post Fri Dec 08, 2006 9:53 pm
i have the plug and play reset tool from ECP as its no longer relevant to my engine.as new still in the box for £5 to cover postage if anyone wants it? im going to have to remove my dash and disconnect all the warning lights as i dont have the port to plug it into on the engine anymore and my dash is lit up like blackpool illuminations at the moment winkeye pm me if you want it :wink:
reddevil
Post Sat Dec 09, 2006 5:38 pm
Worth every penny, I have literally (an hour ago) just bought and used the Draper reset tool for the first time after using the 'wire in hole' method. It's great, all lights reset in about 2 mins, no worries, no cares, just shove it in and press the button. Worth at LEAST £30, never mind the £14 I paid for off Ebay.
Red Devil
Ps toughyv8, if you put a location on your profile, I bet there's someone close-by that will let you use their tool if you get stuck.
1991 (H) 318iS Diamond Black, M-tech II spoiler.
K&N Panel filter-Viper2 chip-Zone BBTB
XBOX LIVE - reddevil1976
toughyv8
Post Sat Dec 09, 2006 5:41 pm
done it peice of cake all lights are out
1900sr
Post Sun Feb 25, 2007 5:41 pm
I've just done this as well, simple. Thanks for the pointers.
666JSB
Post Sun Feb 25, 2007 6:09 pm
fuzzy wrote:i have the plug and play reset tool from ECP as its no longer relevant to my engine.as new still in the box for £5 to cover postage if anyone wants it? im going to have to remove my dash and disconnect all the warning lights as i dont have the port to plug it into on the engine anymore and my dash is lit up like blackpool illuminations at the moment winkeye pm me if you want it :wink:
Just set you PM with my info, Cheers, Neil.
fuzzy
Post Sun Feb 25, 2007 6:12 pm
wouldnt it be cheaper to buy one over there? they are only £15 here but postage to canada will probably cost more than that. ill look into it for you though and get back to you :wink:
666JSB
Post Sun Feb 25, 2007 6:26 pm
Just checked Ebayand there are one or two in the states - post will be U$10 anyhow, UK post - @ £5.
Cheers, Neil.
Post Sun Feb 25, 2007 8:24 pm
What's cheaper and easier than a piece of wire? Takes no longer to plug in than the proper tool.
snoops
Major Helmet
Post Sun Feb 25, 2007 9:00 pm
i used the wire way but some how the green lights went again and the inspection cameon again?
MarkP
Post Sat Mar 03, 2007 3:11 pm
Would it be ok to use a 3amp fuse instead of a 2amp fuse in the wire?
Post Sat Mar 03, 2007 3:13 pm
No, you will end up blowing your car to smithereens! :wink:
MarkP
Post Sat Mar 03, 2007 3:29 pm
Really? :?
So the maximum i can use is 2 amp?
Post Sat Mar 03, 2007 3:31 pm
I was just jesting - any fuse of 5 amps or less should be OK. Some people have managed it with just a length of wire and no fuse at all!
MarkP
Post Sat Mar 03, 2007 3:37 pm
Thanks. I wasnt sure if you were serious or not.
My new sport is getting fully serviced next week but not by BMW and I want to get rid of those annoying lights. :D
Post Sat Mar 03, 2007 8:42 pm
No fuse is required at all! Just a few inches of ordinary car type flexible wire with 10mm bared off at each end.
Just make sure you have identified the two sockets ( 7 and 1 ) on the diagnostic connector correctly.
E30Mark
Post Sat Mar 03, 2007 8:56 pm
Call me a bodger, but i just used a paper clip 8)
PM for details
Ziggy
Post Sat Mar 03, 2007 9:00 pm
Bit o' wire in my ashtray ready & been used many times... along side the safety pin for unblocking/adjusting washer jets :lol:
MarkP
Post Mon Mar 05, 2007 10:04 pm
Well, i got round to doing it. Actually used a bit of wire with a 5amp fuse in between.
I turned and key and VOILA! the service light went away and the green lights went from 1 to full bar.
Problem has arisen out of this!
The green service lights arent staying permanently on, they are meant to arent they? (im not sure :o: )
When i turn the key the light up along with the other lights on the panel but once started they go off again and stay off.
Post Mon Mar 05, 2007 10:43 pm
MarkP wrote: When i turn the key the light up along with the other lights on the panel but once started they go off again and stay off.
which is exactly what they are supposed to do!
MarkP
Post Mon Mar 05, 2007 10:49 pm
Oops! :o:
I wasnt sure. I have been used to looking at the red light.Thanks Brian, cleared that up for me.
