cable root for boot battery
appletree
Post Fri Dec 08, 2006 3:45 pm
can any one tell me the root for the cable when you move the battery from the engine bay to the boot.
mainly location of hole through bulk head.
av searched and looked on the ETK but couldn,t fined it. :?
cheers, matt :D
SPADGE
Post Fri Dec 08, 2006 4:43 pm
Left hand corner to the left of where the battery would have been mate.
I can get you a picture from the actual car in the morning if you like?
Cheers Spadge..
eko
Old timer
Post Fri Dec 08, 2006 4:45 pm
Here you go-Dans318is pic but sure he wont mind!
WillG
Post Fri Dec 08, 2006 4:47 pm
under where the battery in engine bar sits there is a plate i think i goes through there then along drivers side inner sill into a pipe under the back seat which opens in the boot then it runs along inside of of drivers side rear arch and has some plastic trim over it and then goes straight to battery after passing inner arch
WillG
Post Fri Dec 08, 2006 4:48 pm
that is where aircon normaly goes through and on my bros sport it doesnt go throught there it passes under the front battery tray. if you want it to look std then there is also a terminal which screws onto bulkhead and all cables meet there and it has a hinged plastic cover over it, must be diagrams on realoem?
appletree
Post Fri Dec 08, 2006 4:51 pm
cheers lads any pics as above would be great. :cool:
SPADGE
Post Fri Dec 08, 2006 4:56 pm
Will is right mate. I have just removed the air-con from the same car and that picture shows where the pipes went through the bulkhead for that. I'll get you a pic of where it is meant to go as soon as we get some light.
eko
Old timer
Post Fri Dec 08, 2006 5:02 pm
SPADGE wrote:Will is right mate. I have just removed the air-con from the same car and that picture shows where the pipes went through the bulkhead for that. I'll get you a pic of where it is meant to go as soon as we get some light.
Ah wel you live and learn then eh :mad:
Dan has only put his through there because i told him that where id put mine,i only put mine there because thats where RandomDave put his :hammer:
now where is he the fooker...........DAVE :up:
SPADGE
Post Fri Dec 08, 2006 5:07 pm
Eko that may be the correct place for a car that doesn't have factory air con mate!
I've just been outside and manged to get a decent pic of where it went on my car. The top bigger hole is where the factory air-con went through and the hole under and to the right of it is where the battery cable went through. Both these holes go through the same hole in the bulkhead.
Dan318-is
Post Fri Dec 08, 2006 5:12 pm
I would assume the bottom hole in that picture is correct (the more round one) as the grommet i have on the cable does not fit the long thin hole nearest the wing; il investigate tomorrow as i was worried about the grommet especially!
eko
Old timer
Post Fri Dec 08, 2006 5:13 pm
Well either way Spadge theres no going back for me and Dan :roll:
Dan318-is
Post Fri Dec 08, 2006 5:15 pm
eko wrote:Well either way Spadge theres no going back for me and Dan :roll:
True; but i mite rethread the cable through the head and seal the hole up we knocked through tony; would certianly loosen my fear of getting wet feet while driving; having said that like spadge says aircon cars are obviously going to be different as they have all that yidda yadda extra weight comfort wrongness running through them :)
