Speedo Problems
BenE30
Post Fri Dec 08, 2006 10:32 am
Hi,
I have just purchased another 318is and i have noticed that when driving the speedo needle blips all the time, what could this problem be??
Any help would be great,
Many thanks
Ben.
orangecurry
Post Fri Dec 08, 2006 11:11 am
Usually this is caused by the wires running from the sensor on the diff - they snap due to mechanical wear (being over the back axle) - easy fix is to replace the wires from the sensor on the diff to close to where the cable enters the body.
BenE30
Post Fri Dec 08, 2006 1:49 pm
i can do this with any sort of wires can I?? or do i have to replace a part? if any one knows if i need to change a part what part number will i need??
Orangecurry thanks for your help buddy!
Chris-W
Post Fri Dec 08, 2006 2:07 pm
If you need an end plug (they are often nasty & corroded) you can use one from a front fog lamp. Any similar wiring is fine, too.
BenE30
Post Fri Dec 08, 2006 4:44 pm
Cool sounds like an easy fix then!! i will hopefully get it sorted this weekend and get some pictures up of what i did!!
Cheers Chris-W & Orangecurry
:D :D :D
Cheekychunkyfunkymonkey
Post Sat Dec 09, 2006 11:12 am
My needle's just started bouncing up and down like the proverbial brides nightie, so if you let us know how you didi it I'll give it a try also.
Post Sun Feb 18, 2007 4:10 pm
The speed now stopped working altogether and I notice one of the wires has broke off close to where they go into the sensor.
Has anybody fitted one of the repair kits I've heard about?
