i am puttin an early high comp engine into my h reg cabby. i was wonderin if i could use the loom on the cabby???? this would also mean using the late ecu.
i was wonderin if this would still work??
325 early/late wireing loom????
Ant
- Retired Team Member
swop all the ancils over from the late lump and you'll be fine M8. ECU will be a lilttle lame for the CR on that engine, zone chip will give it back some balls
Email FTW
Nelly
- Gumbo
zaust
- Zone day release
- Location: Somewhere in Hertfordshire , or press Ctrl + W
