hi there... very tempted to buy a mild or wild chip from the zone shop as i want to increase the acceleration on my 1988 325i 3 door saloon... which one will be the best chip for me and has anyone got any experience with them... i.e do they make a noticable difference?
thanks
gareth
wild or mild chip???
eltel
Only in the good lord we trust.. In everything else we check!!
1988 325i Tourer, Lowered, Deep Dish Alloys, Obc, Cruise Control, Heated Leather Sport Seats....
doughboy
Got wild on mine, pulls really well. I love it.
mild seems a bit
mild seems a bit
A Mild fitted to my 325iSE gave noticeable torque increase, brought 0-60 time down from 7.3 to 6.7 sec, and raises the rev limit to around 7000rpm...giving an indicated 140 in 4th. No way gay! Low-down torque is what you want for most driving, not peaky top-end power.
eltel
so is that the main difference between the 2..
mild gives better low end torque for acceleration and wild gives more top end speed????
I think the Wild one is really aimed at cars that have been extensively modified with high-lift camshaft, modified head, six-branch exhaust manifold, big-bore throttle body, etc. I.e., intended for cars that you are going to thrash about at high rpm regularly.
Mild gives you a 'driveability upgrade' on a standard engine, eliminating the flat spots and enhancing the torque curve (later 325i's were leaned out alot to reduce emissions; mild chipping restores the low-down grunt). Overall economy surprisingly remains about the same or is actually improved because you can slog along in a higher gear for longer. Yet, the mild chip still gives you extra rpm at the top end, raising the rev limit from around 6,250 to around 6,950 rpm - so really it gives you the best of both worlds
