Starting problems 320i 1989 from cold...help!!!
Rmcm81
Post Thu Dec 07, 2006 1:34 pm
Can any one please help, recentlybought an 'F' reg 320i. been brilliant past few weeks but slowly starting it in the morning or from cold has become a complete nightmare! done the usual things, checked plugs cleaned airflow and idle valve. and was fine after that, but its become worse again! what can i do its embarasing! when cranking it i gently press the accelerator pedal and can smell fuel so i know its getting fuel to it, when it does eventually start with a bit of a rev there seems to me to be no actual cold start revving ( i expect it to rev at at least 1200 from cold for a while? or is that just me? ) when it goes it really goes well no cutting out no hesitations. need to sort it asap...PLEASE HELP!! P.S if any one has a diff lying around i would be interested, Cheers :cool:
marty1979
Post Thu Dec 07, 2006 4:26 pm
Hi there mate, I've got an F reg 320 also. Do you hear the fuel pump priming before the last click on the ignition? If not there might be a problem with the relay or pump itself. Also, try starting it without pressing the accelerator pedal, if you can smell fuel before it starts then it could be that you're flooding it? Also try your distibutor cap, it might be cacked up?
Nelly
Gumbo
Gumbo
Post Thu Dec 07, 2006 8:53 pm
Change both the Blue + the Brown sensers in the thermostate housing - if this fails, clean the face of the crank position senser located on the drivers side about 4mm from the timing wheel on the front of the engine.
Last ditch, try another ECU in it.
Neil.
"I F**KING LOVE YOU GUMBO"
SGP
Post Thu Dec 07, 2006 10:45 pm
The accelerator pedal should not be depressed when starting.it opens the throttle position switch and will lead to flooding.The brown sender has no bearing on the engine performance it simply controls the temp guage.lol
If it ain't broke..
Fix it till it is :)
Nelly
Gumbo
Gumbo
Post Fri Dec 08, 2006 12:40 am
But if your there doing the nasty Blue, for the amount it costs, you might as well change both.
