a quick question for brianmoore...and anyone else who might know
will a lamba sensor from an e34(m20) fit a e30( m20)..they use the same universal no but according to realoem are different lengths?
lamba sensor question
Length of lead and the plug on the end might be different, but otherwise most lambda sensors are the same, whatever car they come off.
Don't know about the E34 M20 specifically, but I've used M50 E34, E36, E39 and Ford lambdas on E30s.
1, 2, 3 and 4 wire types are all interchangeable as well, subject to certain conditions.
There are other types of lambda sensor around, but most are 0-1 volt M18X 1.5 types.
DaveD
- E30Zone Wiki Specialist
thanks very much..i will bid for this one i found then
