ECU Differences
Cyruz
I've finally got my car running on an old ECU but as soon as I run the chip for my injectors it won't turn over. I then realised the number on the chip was the ECU code and was a 173 and my car uses a 073, are these ECU's interchangable as the chip refused to work on my car. 87' 325i m20 high compression engine
zaust
- Zone day release
- Location: Somewhere in Hertfordshire , or press Ctrl + W
GDBN
Talk to Ant if you want the 073 chipping.
If you are competant at soldering then you could do it yourself as you will be going from a 24 pin chip to 28.
He did mine and it's pretty good.
G
G
