325i Touring 1989,Long story.
Two years ago I got a new 274/274 cam fitted.
The car was running rough when I bought it and I put it down to the cam being worn out.
The private guy that fitted it just couldnt get the engine to run properly.
I drove it for 6 months with the starting problems getting worse.
But it was not just the starting problem.
Sometimes the car when crusing would cut out for 0.5 sec then continue to cruse along on part throtal ok.
It was as if all the electric connections to the motor were for a 0.5 sec completly cut.
I took it to a bmw specialist garage 18 month ago.
They went though everything ( Everything? ) so they said.
They put it down to a faulty crankcase sensor which they relaced.
They also said it was down 25% compression on all 6 cylinders,
later I found out this is normal from a non skimed head fitted with a performance cam.
When I got the car back it ran ok but rough idle and bad full economy.
I put up with it and rode my Ktm to work all summer out of choice naturaly!!
Come the winter and my bemmer is back in full time use.
Cleaned the tb and all bits as per zone articale,
re-adjusted the butterfly in the tb and adjusted the throtal control unit under the tb so it clicked just after opening the butterfly.
It was way out of wack.
When I started it from cold for the first time she idled at 1000 then setteled down to 800.
2 days later the car starts ok but only goes to 600 (from cold to hot temp.)
Then when I move forward and put her under load she dies,
Wont start and takes a good deal of cracking to get her going again, full of fuel and rough as a kho phan ghan full moon party vet.
Changed the blue temp sensor again ( twice in the past two years )
I have a feeling this isnt going to help.
Will know for sure at 6.35am!
The engine bay smels of petrol only after I have cranked her over and got her going again so I dont know if this is a leak or resault of pumping the throtal.
I think this is an electrical problem but I am not sure!
More Cutting out issues pls help!
toughguych
toby
Sounds like an electrical problem if you are smelling fuel and difficulties in the fire up.
Have you checked distributer cap and rotor arm? (Allen keys required for original rotor arm.) If you've never replaced them might be worth changing them anyway - they never last forever.
Not really what you want to messing around with at 6.35am is it?
It will still be bloody dark then too. Symapthies dude.
toughguych
Wierd thing is, closing the bt butterfly comletly so that the throttal sensor does not click as soon as it is opened makes the car start ok...
Maybe I should just return the tb settings to what they were B4 I did the clean up!
At least it started ok.
Ho and changing the blue temp sensor has made no difference at all!
The problem is not with cap and rotor.
