help advise needed newbie
th3_duckst3r
Post Tue Dec 05, 2006 5:04 pm
just a couple of quick questions and im a newbie on the forums havin just purchased a 1989 f plate 320i 2 door coupe all in good condition.but im not sure how the obc works mines fitted to roof just below sunroof i have no idea how it works so help on this matter plz also there was no stereo in car so fitted my own.but downside is leccy ariel dosent seem to work how can i test this to make sure its not just totally dead before getting a new one also stereo dosent seem to hold its memory which wire should i b looking at to fix this.ill up some picks of my ride in due course wen i find some batterys for me cam any helps thank you..
smithy318i
Post Tue Dec 05, 2006 5:26 pm
Hello and welcome to the zone.
Firstly, the panel of lights above your head isn't the OBC, it's called the check control panel. The LED's light up when something is wrong. (LED's are like bulbs btw)
To test the electric ariel, you will need to remove the passenger side light bulb assembly from the rear cluster. To do this, just twist the knob to the open position and pull. Then you can pull the trim away from the inside of the boot to reveal the electric ariel. There should be 3 wires connected to the base of the unit. two are positive and the other is negative. to test if it is working you will need to suply 12 volts to both of the + wires (these could be red or green or yellow or white or blue or blue/white but not black or brown)
as for memory for the radio... erm... it would appear that you have the perm 12V wire and the acc 12V wire the wrong way round.
hope thst helps.
J_Mac
Post Tue Dec 05, 2006 8:08 pm
I agree, up top's just the control panel, when things go wrong and things run out, lights will come on (washer fuild low ect) the obc left of your stereo and it'll tell you the range in mile/kilometres of fuel you have in the tank, average consumption, outside temp ect ect
on the back of the stereo do you have a wiring diagram (what the wires are in their colours) one of them will be the ariel, if not, you connect the ariel to the ignition live via the back of the stereo.. and if the stereo's working with the ignition on, then yes sounds like you have the ignition live and the permanent live round the wrong way
th3_duckst3r
Post Wed Dec 06, 2006 10:48 am
thank you for replies hopefully i can now get some where :x
