The OBC panel on my Touring has started to leak, as I'm pretty sure the OBC panel doesn't contain water, guess I've got a water coming through the roof somewhere!
What's the most likely ingress spot, sunroof or aerial? It is actually dripping from the mirror mount and how easy is it to remove the OBC panel and aerial?
And has anyone removed the roof aerial? Pics please........I think it'd improve the look of the car!
Andy
Water leak from OBC panel
ian332isport
Andy,
It's more than likely that it's the aerial that's causing the leak. I believe the check control panel (OBC is in the dash when fitted) is just clipped into place and just simply down.
You probably just need to take the aerial off and either clean the seal if in good condition, and/or use a bit of sealer. Not sure if the seal is available on its own though.
Ian.
Ian.
andyborris
Thanks Ian, think I might have a go at removing it completely, always thought it's a bit of a ugly lump on the roof!
ian332isport
You'll have a hole in the roof thenandyborris wrote:Thanks Ian, think I might have a go at removing it completely, always thought it's a bit of a ugly lump on the roof!
andyborris
Nothing a nice BMW sticker won't cure!ian332isport wrote:You'll have a hole in the roof thenandyborris wrote:Thanks Ian, think I might have a go at removing it completely, always thought it's a bit of a ugly lump on the roof!
