locked door problem
Paul_C
Post Tue Dec 05, 2006 1:23 am
Hi guys, first post and I'm after some help if possible.
I have an E reg 4 dr 318i and the solenoid on the driver's side rear door appears to have given up the ghost, sadly for me in the locked position. I guess the lock mechanism could be the problem, but it's not easy to diagnose until the door's open ;)
I've got the inside panel off but would appreciate any tips as to how to get the door open. I tried using the door pin while locking/unlocking the driver's door, but only succeeded in bending the rod, so it's good and stuck.
So, anyone know what I should try next ?
Thanks in advance if anyone does know :)
Paul.
ian332isport
Post Tue Dec 05, 2006 1:28 am
Hi Paul,
Welcome to the zone 8)
Assuming it is the solenoid that's jammed up, you could just undo the two screws that secure it to the door. Once loose, you should be able to push/pull the locking rod and unlock it.
Ian.
Paul_C
Post Tue Dec 05, 2006 1:30 am
and this can be done with the door shut ?
I'll have a rummage about tomorrow then, cheers !
P.
ian332isport
Post Tue Dec 05, 2006 1:35 am
Paul_C wrote:and this can be done with the door shut ?
As long as the door card is removed, you should be able to see the locking solenoid with the door shut. You may have to move/tilt/slide the seat to get at it though.
Ian.
Paul_C
Post Tue Dec 05, 2006 1:41 am
excellent :)
I'll save my questions on keeping water out of the boot (possibly coming in through the tail lights while parked on a steep driveway ?) /squeaky steering wheel (boss rubbing on the light/wiper cluster ?) /leaky sunroof (new trim? ) for another day ;)
It's not a match for some of the beauties I've seen on here, and is obviously in need of quite a bit of TLC, but I'd still rather have it than some boring jelly-mould modern stuff.
cheers,
Paul.
ian332isport
Post Tue Dec 05, 2006 2:06 am
Paul_C wrote:I'll save my questions on keeping water out of the boot (possibly coming in through the tail lights while parked on a steep driveway ?) /squeaky steering wheel (boss rubbing on the light/wiper cluster ?) /leaky sunroof (new trim? ) for another day ;)
Leaky boot could be the tail light gaskets (common), but this is not usually parking angle dependant. Could also be a leaky boot seal which is also quite common and can be angle dependant (parking nose down is worst).
Squeaky steering is probably the graphite contact for the horn ring. You just need to take the wheel off and put a bit of copper grease on the ring.
Sunroof could be a variety of things:
Blocked drain tubes.
Out of place or rusty rain channel that clips to the rear of the sunroof lining.
Rusty sunroof support tray.
It's not going to be the rubber seal around the edge of the sunroof, as this is only really there to stop wind noise.
Ian.
Paul_C
Post Tue Dec 05, 2006 12:25 pm
thanks for all those suggestions - I'll update as and when progress is made ..
Paul.
Paul_C
Post Sun Dec 10, 2006 10:36 am
Well the squeak from the steering is no better, despite grease on anything that moves ..
I can only assume there's a lack of lubrication in the steering shaft - can the inner be separated from the outer, or is it a matter of replacement ?
Either way I have neither the time, the facilities nor the inclination, so it's off to the garage for the next step
P.
