petrol pump help needed
johneiuk
Post Mon Dec 04, 2006 11:12 pm
i took this picture from the articles page about changing a petrol pump and added to it. i need a petrol pump as mine has gone to heaven my petrol pump is the same as the one picture but mine has 2 pipes coming of of it not one. please help if any1 knows the part number or where i can get one from many thanks john
http://img362.imageshack.us/img362/2250 ... mp5uj5.jpg
Post Mon Dec 04, 2006 11:18 pm
The extra pipe is the return fuel pipe from the pressure regulator on the engine fuel rail. Cars which use the single pipe pump like the one in the picture have an extra pipe into the tank instead.
If you can only find a single pipe replacement pump, then it's not a difficult job to transfer the actual pump to your original mounting bracket.
johneiuk
Post Mon Dec 04, 2006 11:32 pm
it would fit not a problem just dont know what to do with the other pipe as i cant see a way to join it to the tank no other way.
Post Mon Dec 04, 2006 11:48 pm
Brianmoooore wrote: If you can only find a single pipe replacement pump, then it's not a difficult job to transfer the actual pump to your original mounting bracket.
johneiuk
Post Thu Dec 07, 2006 12:01 am
do i have to un solder the wires or is there any other way to do it.
Post Thu Dec 07, 2006 12:04 am
Wires have to be soldered, and properly.
johneiuk
Post Thu Dec 07, 2006 10:05 am
k thank you so much for your help i will have a go later.
