OBC Woes
Foomanchu
Post Sun Dec 03, 2006 11:48 am
Hi I have just got my car back from the garage... It has just had a 2.7 conversion carried out and I'm slowly running it in...
But my OBC now doesn't show MPG readings or AVG speed I'm just wondering if there is a reset anywhere..
Lui
rj
Post Sun Dec 03, 2006 12:41 pm
Hi Lui
If I remember correctly to reset the OBC:
First, press CODE button, and then press the small recessed button on the lower right of the unit. Keep it pressed and then the LED in the M MPH button will flash once, and the OBC is reset. Youl have to then reset the date and time etc as all memory is wiped clean.
Regan
Foomanchu
Post Sun Dec 03, 2006 12:54 pm
Cheers Pal.
orangecurry
Post Sun Dec 03, 2006 12:57 pm
If the above does NOT work, try disconnecting, then reconnecting the OBC with the ignition on.
I did this by pulling the yellow plug from the instrument cluster, whilst the cluster was out and the rear accessable, obviously :D .
You can check the condition of the little batteries whilst you are there.
