Following the advise from one of our fellow zoners, in a very well writen and helpful articale, I set about my Throttle body.
Got to the point where I needed to remove the water heated unit on the left side of the throrrle body.
It does say in the articale that if the hex screws dont give a little when undoing then dont persue this part of the cleaning process further.
Well, they seemed to shift ok but one of the heads just came off and left the thread in there.
Not going to carry on with that part of the cleaning job, just pulled out the two remaining hex screws and cleaned them up, copperslip and screwed back in.
So now I have something else to worry about with my glorious E30!
Was going to drill it out but with a good clean and a dap of liquid gaskit it shoud be ok.
Main reason why I am telling you this is because if you want to clean you throttle body I would advise against trying to take the water heater unit off.
bottom screw is to likely to snap, well in my case anyway.
toughguych
Throttle Body Cleaning
toughguych
marty1979
I did mine the other day but I didn't go as far as you, I only cleaned the throttle body and the TPS. The casing for my TPS was full of oil and the switch wasn't working properly, gave it a good clean out and it's like new now. Might be worth having a look at yours if you haven't already done so.
toughguych
Thanks Marty,
Yes I did my tps. It needed adjustment and the car does run alot better now.
Just need to keep an eye on the water around the tb heater matrix. It looks like leaking slightly.
Guess I will have to do the water by pass job.
Cheers.
Cheers.
