Information on HARTGE H5SP engine.
JimsE30
Post Sat Dec 02, 2006 2:39 pm
First of all a quick thanks to all that contribute to this forum, im a newbee to the zone, but i already have much of the info i need for a possible 335i conversion.
Ok, whilst looking for a decent 3.5l engine, i stumbled across a none road worthy Hartge H5SP. However the engine is fine. Did Hartge do anything particular to this 3.5l engine to improve the performance, or is there anything different about this engine that would change the 335i conversion?
Id appreciate any info at all, as im so far found very little.
Thanks again!
James
Theo
Post Sat Dec 02, 2006 4:47 pm
Hi there, sounds like an interesting find, would be great to see some pics if possible!
Was it an E28 or E34? I think the H5SP got 254bhp out of the m30, where as the standard H5 got 240bhp. If you go to www.e30.de you will see that there is a section all about Hartge cars, and in there is shows that the H35 (Hartge's E30 with M30) was available in two differnet tunes (which I assume to be the same as the two variants of the H5).
Max power - 187kw(254ps)/6100rpm.
Max torque - 340(nm)/4000rpm.
Compresion ratio - 10.2:1.
Also appears to have a 282degree cam, and a 6 branch manifold, the latter of which if you have, is going to be fun and games to fit in a RHD E30!
Also found this link with some pics of an e28 h5sp - the only one in germany no less!
http://www.euromcars.com/cars/86h5sp/
JimsE30
Post Sat Dec 02, 2006 5:59 pm
Cheers Theo!
6 branch manifold snag possibly then! Guess i might have to replace it with a Turbo manifold instead! Lol.
Will get some pics when its light outside. Its also got a beautiful set of Hartge 16" alloys on it. The body is completely rotten and of not much use at all.
They must of looked into the future back in 86' as its got a Hartge stainless steel centre exit letterbox exhaust on it. So im sorry Corsa and Nova boys, Hartge did it first!
Thanks again
James
JimsE30
Post Sat Dec 02, 2006 6:07 pm
Forgot to say it is a E28, identical to the one you found on that german website, but in white. So i guess if there is only 1 in Germany, there cant be that many in the UK.
Theo
Post Sat Dec 02, 2006 6:14 pm
No worries James, sounds like an excellent find, but would it not be an idea to reshell the car and get it back to its former glory? Would be a valuable car if you did.
Andy335Touring
Post Sat Dec 02, 2006 9:00 pm
You will have to swap the sump and oil pick up pipe(or oil pump ?) to the later E32/4 items, not sure when they stopped doing it but the earlier ones had a coolant pipe that comes out of the back of the head which could give you some extra bulk head clearancing work to get the engine in P3(furthest back).
The sump and the oil pump i have spares of if you need them.
This is may be not the best engine to turbo charge due to the high(ish) C/R, stock E34/2 M30's are 9.0:1 so will allow you more boost before it complains.
HTH
