Cheers Spadge...
Another question this time about the diff speed sensor.
SPADGE
The other day i replaced the diff in my 320 touring with on from a D plate pre-facelift. The only problem is the plug on the 320 for the speed sensor is different to the socket on the diff
Now can i just splice the earlier plug on or shall i just use a speed sensor from a later car?
Cheers Spadge...
Cheers Spadge...
Dan318-is
Earlier and later plugs were slightly different. you should be able to use a later plug without problems!
SPADGE
Its all your faultDan318-is wrote:Earlier and later plugs were slightly different. you should be able to use a later plug without problems!
Where is my feedback btw you tight arse
