Rear window removal on a 2door e30
320Touring
Post Wed Nov 29, 2006 3:56 pm
Time has come to remove the rear window on the iS- what is the best way to go about it without damaging the demister wires?
what side do the wires run up?
I usually do glass removal with a ball-peen :twisted: so any less destructive ideas would be welcomed :cool:
buster
Post Wed Nov 29, 2006 5:32 pm
pull out the 2 metal holders which are fitted on the outside lower corners.Pull out the centre upper and lower seal trims,unplug the 2 demister wires (one in each lower corner),then with the aid of a friend on the outside to catch the glass,gentally push out from the inside.
320Touring
Post Wed Nov 29, 2006 5:35 pm
buster wrote:pull out the 2 metal holders which are fitted on the outside lower corners.Pull out the centre upper and lower seal trims,unplug the 2 demister wires (one in each lower corner),then with the aid of a friend on the outside to catch the glass,gentally push out from the inside.
Ideal sir :D
buster
Post Wed Nov 29, 2006 5:38 pm
No probs mate.Only thing is getting it back in.
The plastic trim peices are a pain to get back in.You need a proper tool to put them in,but you can get away with using various blunt objects as long as your carefull.And plenty of fairy liquid !!
320Touring
Post Wed Nov 29, 2006 5:47 pm
buster wrote:No probs mate.Only thing is getting it back in.
that'll be the buyers issue :wink:
just removing to pass on :cool:
buster
Post Wed Nov 29, 2006 5:49 pm
sorted :thumb:
