SPEEDOMETER REPLACEMENT
marchad
Post Wed Nov 29, 2006 5:33 am
well ive replaced my odometer gear and it still doesn't work
i think the motor that turns the little gear has stopped working
how would i go about getting a new speedometer or where can i find a refurbed one. if anyone could help i would really apreciate it.
marchad
Post Sun Dec 03, 2006 8:54 am
come on someone please help me
i need to get it fixed so i can drive my car... my insurance company won't insure me without it :cry:
Chris-W
Post Sun Dec 03, 2006 9:09 am
Are you sure that it's not the wiring from the sensor on the diff which is at fault?
Post Sun Dec 03, 2006 11:47 am
If the speedo works and the odometer doesn't, then it can only be the speedo assembly itself.
This fault is unheard of in the UK, but seems to be common in the US and a few other countries!
The cause is usually failure of a couple of plastic gears, which are available in the US, and are different between the different makes of cluster.
It's possible for any component to fail of course, but I've never heard of a failed drive motor.
Would have thought a speedo assembly or complete cluster from a scrapyard would be the way to go.
