Removing Dials/Clocks
wildeian
Post Mon Nov 27, 2006 9:54 pm
Started to strip out the dash the other day, and its free to move just being held on by cables, wires etc.
Are the clocks removed from the rear, or can they be done with the dash in situ?
Taylor325i
Location: Kilmarnock, Ayrshire, Scotland. Brilliant Red Tech II 325i.
Post Mon Nov 27, 2006 10:02 pm
The clocks come out with the dash in situ but you'll need to remove the steering wheel.
Taylor.
wildeian
Post Mon Nov 27, 2006 10:10 pm
Cheers Taylor
stuartgallafant
Post Mon Nov 27, 2006 10:12 pm
Taylor325i wrote:but you'll need to remove the steering wheel
no you dont...
theres 2 10mm screw plugs on the back of the plastic panel under the clocks. reach behind and undo them, then pull out the panel
then, undo the 4/6 screws holding in the plastic trim surround
then, undo the 2 screws holding the clocks in, pull it all forward. then lean it forward, and pull it out sideways behind the wheel
wildeian
Post Mon Nov 27, 2006 10:41 pm
Cheers Stuart! :notworthy:
Taylor325i
Post Tue Nov 28, 2006 5:09 pm
no you dont...
Sorry for the wrong info - I've never tried it with the steering wheel still on I just assumed that the clocks wouldn't fit through the gap. You learn something new every day.
Taylor.
Post Tue Nov 28, 2006 11:16 pm
Lay the clocks face down on top of the column shroud as you pull them out, and there's just room to slide them out to the left.
E30Mark
Post Tue Nov 28, 2006 11:24 pm
Download the following file, hopefully it may help!
I don't think there are any errors in it, if there are let me know and i'll update the write up!
http://www.mark-e-roberts.co.uk/220%20o ... cedure.doc
PM for details
Post Wed Nov 29, 2006 12:03 am
On second thoughts, the write up is correct - you do pull the cluster out face up, not face down as i said.
wildeian
Post Wed Nov 29, 2006 1:15 pm
Cheers all!
Good guide there Mark.
