Carb Cleaner
toughguych
Post Mon Nov 27, 2006 8:21 pm
I stumbled across a topic detailing how a good dose of carb cleaner sprayed into the inlet manifold will help the engine run smoother.
Cant find the topic again.
Whats the best process for carrying out this job please?
Which part to spray into etc..
Cheers. 8O
Martinaston
Post Mon Nov 27, 2006 8:38 pm
If you just spray it into the manifold it will just ignite and speed the engine up.
If you want it to work correctly then you need to remove thr icv and clean it with an old toothbrush and carb cleaner, then check the tps, cap and arm and plugs.
There is NO nucleus.
toughguych
Post Mon Nov 27, 2006 9:26 pm
Cap and arm plus plugs done already.
icv?, tps?
Will look in Haynes.
Cheers.
blingsta
Boost Junkie
Post Mon Nov 27, 2006 9:35 pm
idle control vale and throttle position sensor.. :D
toughguych
Post Mon Nov 27, 2006 9:56 pm
Thought so but will have to investigate taking apart.
Thanks.
