Hi guys's
Just a quick question for you! I have a 1986 318i which when on a run on Sat with 3 mates in car the temperature dial crept up to midway bewteen half way and 3 quarters. Was a little worried!!! Then yesterday it was back to its normal position of sitting a tiny fraction just over halfway. She has a new Rad and pipes so cooling shouldnt be a problem!!
Any idea's??
Oh and when does the fan kick in?
Look forward to your responses!!! Hopefully it was just the weight of 3 heavy rugby players plus their kit in the car which she objected to??!!?
Temp level??!!
RugbySteve
stranter
Sounds like your thermostat might be knackered. Worth replacing, they're only a few quid from GSF. While you're at it replace the viscous fan, these often go which is the cause of most M10 cooling problems in my experience. Oh and a new rad cap, old worn ones can often lead to overheating.
Stewart
Stewart
RugbySteve
Cheers for the reply Stewart,
Will have a look this weekend in the day light and then go get the parts needed! and have a play under the hood!!!!
It only happens when driving at speed, when in traffic its fine so im guessing the viscous fan is fine at the mo, but will look at that aswell anyway!!
