missing relay??
timmyboy
Post Sat Nov 25, 2006 4:57 pm
on the near side wing there is a black cover over a couple of relays, i have a white one and a brown one.
thre is space for another one though, does anybody no if there should be another relay there?
if so what does it do and what colour is it?
cheers tim
(00=[ll]=00)
Image<embed></embed>
ian332isport
Post Sat Nov 25, 2006 5:49 pm
timmyboy wrote:on the near side wing there is a black cover over a couple of relays, i have a white one and a brown one.
cheers tim
Tim,
That spare socket is for the Lambda sensor heater relay. Most later E30's were CAT ready, but unless you had the CAT fitted, they never fitted the relay of the Lambda sensor.
If you have a feel under the front battery tray (sort of down below the clutch fluid reservoir), you will find the connector for the Lambda sensor with a blanking cap over it.
Ian.
timmyboy
Post Sat Nov 25, 2006 5:50 pm
lovely cheers mate. :D
(00=[ll]=00)
