Alright,
I thought I'd give the above a go using the write up in the articles section, but when i connect a wire from the hazzards to the heater switch, the heater switch lights up as if its on even though it's not (if that makes any sense?)
Just wondering if anyone has had the same problem & knows how to sort it?
Stu
Illuminated Rear Heater Switch
beemerstu84
smithy318i
what the article doesn't say is, you need to swap the demist switch with a spare hazard switch and swap the face of the buttons.
and also attach a second wire. then it will work.
smithy318i
beemerstu84
ahhh, that mite help. Thanks Smithy
So anyone got a spare hazzard switch?
cheers
cheers
smithy318i
beemerstu84
All makes sense now & i found a switch on ebay its sittin at 99p woohoo!
Thanks again!
Thanks again!
stuartgallafant
smithy318i
the demist switch is dimly illuminated in the dark just like the hazard switch. And bright when switched on.stuartgallafant wrote:so whats the advantage/outcome of this mod then?
stuartgallafant
smithy318i
erm........... yellow.
stuartgallafant
ian332isport
The article was written based on using a modified demister switch rather than a hazard switch with the cover swapped. It's 100% accurate if using a correctly modified switch. It was also written before it was found that you can swap the covers over.smithy318i wrote:what the article doesn't say is, you need to swap the demist switch with a spare hazard switch and swap the face of the buttons.
Ian.
FlashBastd
So I have now done this mod to mine, and it lights up, but seems dim compared to the rear wash wipe and hazard switches. Any ideas?
1993 E30 318i Lux Auto Touring - SOLD
2001 Ford Mondeo 2.5 Zetec-S 5dr - SOLD
2004 Lexus IS300 Limited Edition Auto - SOLD
2005 Honda CR-V 2.0i Executive Auto
2001 Ford Puma 1.7i Black
