Also which spark plugs for my M20, shall i go for bosch coz i cant find anywhere that will do NGK, halfrauds dont do em, shal i go to halfords or i have a little specialist german parts shop, think they get most stuff from GSF or ECP, or i have a Motorist Discount Centre too!
service confusion..
Kam320i_cab
hi all, went to get service parts today but come back with nowt coz they had different types of rotor arms!! which one do i go for??
E30Adam
There should only be one type of rotor arm for your car, BMW part number is 12.11.1.734.110
My local Halfords sells the NGK's so you might want to try a larger store or ask if they can get them in for you. If you really can't find the NGK's then Bosch will be just fine. As long as the thing sparks then that's all you need. All these fancy grooved ones and fancy plugs are just a gimmick.
Problem with plugs from Halfrauds, is that they come in packs of four, so you have to buy eight.
I get on OK ith Beru plugs from GSF or Eurocarparts.(Can't remember which).
andyp
- True Old Skooler
mine also sells them and single,
johnono
got 6 bosch the other week
20 for 6 peices..not too bad
w8lcr is the code i needed
