inlet manifold
baxter
are all 6 pot inlet manifold the same, as i need a flange to mate with my m20 325 engine
SGP
The 2ltr engine has a smaller throttle body opening.
If it ain't broke..
Fix it till it is
Fix it till it is
Chris-W
bigkev
Templ8e30
The flanges have the same hole centres etc but have a slightly different port shape.
You could easily re-shape them with a die grinder or dremel and a 325i inlet gasket though.
Cheers,
Iain T
Cheers,
Iain T
2007 Mazda 6 2.0 estate
