Can anybody shed some light on where the ignition relay is located on an '87 H27/325i?
Desperate to bypass the alarm this saturday!....
Cheers!
Ignition relay location????
There is no ignition relay as such. The ignition coil is fed directly from the ignition switch.
The engine ECU main power feed is fed by a relay though, and this is located, along with the fuel pump relay and a usually empty socket for a lambda sensor heater, under a plastic cover on the inner wing near the air filter.
