hi ppl, ive taken my bmw to be serviced and the bloke says it dosent need doing bcuz it dosent do enough millage to be serviced again for another so many 1000 miles!
just wondering how i turn these off?
Lee
how to switch off the inspection lights?
Zayyan
You need a service light reset tool I think
You could get one off eBay...
http://search.ebay.co.uk/bmw-reset-tool ... 9QQfromZR8
Tho I'm sure someone on here'll have one who'll bring it along for you if you're going to the same meet
ed325i
Hi, you can do it by earthing one of the wires out, can't remember which one someone will tell you.
ED
ED
Borderbmw
Think its pin 7 you can earth out to reset them,but be careful or you will bugger something else up!
E30_320i
cheers lads, think ill just buy the draper service key rather than earthing the pin, which like you say if done wrong can bugger sommit else up
Lee
Lee
mrLEE30
ignition off short out pins 7 and 11 inside your inspection socket (next to the inlet manifold) i use a paper clip but some suggest a fused wire, so long as you get the right pins a paper clip is fine( note the pin numbers are written next to the pins on the newer bigger type plugs, and on the inside of the cap on the older smaller plugs, the older smaller ones you have to remember that when the cap is upside down the pin numbers are reversed i.e. the pin diagram is only correct when the cap is on the plug and thus un-seeable (confused? no? good)
then with pins shorted turn on ignition (but don't start) and wait approximately 5-8 seconds, your oil inspection light should then go out. turn off ignition and back on again (dont start) and wait anothert 5-8 secs at that point the five green lights should come on and you have a full service!!
easy peasy
mr lee
easy peasy
mr lee
stevo
E30_320i
cheers ppl
i tried the method in the link stevo and it didnt work.
mrLEE30: at the moment when you turn the ignition on, it gives you the 5 green Led's and the "Inspection" light.
when you start the car the 5 green Led's go out, but the "inspection" light is still on???
i tried your method mate and it didnt knock the "inspection" light off? and next to the "inspection" light is a symbol, its like a circle with a quarter cut out of it? is this right?
Lee
Lee
A1BMW325iSport
pin 7 to earth, make sure its good connection and turn ignition on leave for 15secs then inspection should go out
mrLEE30
yeah that is the oil inspection light and it comes on with mileage and not due to a problem i believe. try as A1bmw says and leave it on for a bit longer, i short 7 and 11 but he suggests grounding pin 7. if it still wont go out then most likely the battery in your Si board is flat and needs relplacing, not too hard a job.
mr lee
mr lee
