Hiya,
My mate has just swapped the head on his E30 325i tourer. The head he's put on has got re-profiled cam. His engine builder has assured him that the cam should not cause any engine running problems, however...
The head has now been fitted but on tickover the engine surges from between 800rpm to 2k rpm and the engine does not seem to want to accelerate.
Can anybody think what the problem is? He's checked all the vacuum hoses and electrical connections and everything seems to be ok?
Any help would be appreciated.
Matt
Problem after changing head on E30 325i
ed325i
sounds like an air leak some where. Is the oil breather pipe between the block and inlet sealed ok ?
Where are you in cambs.
E30Adam
I'd second that, definate air leak methinks.
Check the corrugated hose from the TB to the AFM, these are prone to splitting especially underneath out of sight.
Also a blocked breather as has been mentioned above would cause this problem.
Nelly
- Gumbo
Martinaston
Fuel lines the right way round ?
There is NO nucleus.
stitch-626
just a stupid suggestion (i've done this myself) is the air flow meter plugged in?
i drove round for a few days like this it took a woman to spot it it was that daft!
wanted passenger side rear door for touring.pref dark blue
wanted, toy Bmw's any series, not for me for my 3year old daughter.
I have a rondevous with death, i drive an E30 in scotland
