Hi Guy's
Just wondering how best to take out the door cards (front and back)on my e30 coupe????, any suggestetions?
cheers
Fal
Door card removal???
liam012
ok
the front cards you must
i)unscrew three philips
screws (one of them is hidden behind a black plastic faceplate or the controls for your electric sidemirrors)
ii)unscrew the plastic door knob
iii)the black plastic frame around the door release handle needs to be pushed/slid forward and unclipped
iv)starting at the botttom gently pull the card away from the door you will see where the clips are - you may or may not brake all or none of them - it is pot luck.
v)when the clips are all popped then you remove the card by lifting it up first so it unhooks from the doorframe where the window goes up and down.
the backs are easier
i)remove rear bench and back seat for ease
ii)un pop a few clips
ii)again lift/slide up then away from the car
think thats everything
Fal_325i
cheers mate
