Cold Starting problem
Colonelmark
Post Fri Nov 17, 2006 2:28 pm
Can anyone point me in the right direction?
Just bought C reg 320 -my first E30 - and when it is cold the engine starts but doesn't hold the revs and stalls. Will start everytime no problem but will only hold revs if I keep my foot on the throttle to keep the revs up. It's fine once warmed through, only happens when it's cold????
Ant
Retired Team Member
Retired Team Member
Post Fri Nov 17, 2006 2:32 pm
the aux cold start valve has failed dude
cant recall what type but on LE Jetroinc there are two possibilities
you either have a water heated "wax-stat" under the inlet manifold, or there's an electric valve with a heater element and rotating disc under the back of the intake manifold, rocker cover side
in either case, it would seem to be the culprit as the cold start enrichment requires more air to reach fast idle.
post a pic or two up of the engine bay, but I'm confident its the cause dude
Welcome to the zone too fella :thumb:
Colonelmark
Post Sat Nov 18, 2006 8:08 pm
Thanks Ant, will post some pics ASAP. :D
JAFF
Post Sat Nov 18, 2006 9:12 pm
iv had the same prob on my 320 if i dont hold the throttle open for a second it wont start for ages after and i mean ages other than that i love my e30 :D
