Power Steering reservoir leak
chief
Post Fri Nov 17, 2006 1:55 pm
on close inspection it appears that the power steering has a leak where the 2 pipes connect under the reservoir bottle.
the 2 clamps don't appear to be adjustable with a spanner like the ones on fuel lines etc.
can i get these off and replace with adjustable ones that i can tighten to the desired level to stop the leak or must i use the original style ones
Don't you wish there were a knob on the TV to turn up the intelligence? There's one marked 'Brightness', but it doesn't work.
eko
Old timer
Post Fri Nov 17, 2006 1:59 pm
Jubilee clips mate :D
