Dodgy Cold Start!! AHH!!
geo1400
Fri Nov 17, 2006 11:13 am
I've had this problem for a while and just tinkered away trying to figure the problem by changing things.
The Symptoms: If the car sits for more than 2 hours(approx), its struggles to start. It will turn over for about 6 -7 seconds then cough splutter and kick in. Then the idle is really rough unless I give it a little throttle. Once it's cleared its throat its runs real nice. And if I turn the engine off straight after the struggled start, it will start again first turn!
What I've done:
Second Hand ICV (made a huge difference in the idle) along with with new piping surrounding the ICV.
New Starter Motor
New Ignition Leads
Recent Service
New Belts
Second Hand Fuel regulator valve
New blue temp sensor
Inlet and manifold gaskets (also done a search for air leaks)
A few other things that i've forgotting about...
Anyone any ideas? please help it hurts me every time I hear my motor struggle? :cry:
Geo1400
TouringMatt
Fri Nov 17, 2006 5:25 pm
What idle speed do you get on a cold engine?
What engine BTW?
Matt
geo1400
Fri Nov 17, 2006 7:40 pm
Once it's coughed and spluttered it idles about 1000rpm for a little while and then it settles at about 800rpm.
What does BTW mean? it's gonna be really obvious I know but i'm a bit dense.
I did forget to mention it's a 318i - M40
Cheers Matt
Gortour
Fri Nov 17, 2006 7:43 pm
BTW = By The Way
geo1400
Fri Nov 17, 2006 7:45 pm
Ta :o:
TouringMatt
Fri Nov 17, 2006 7:50 pm
I had the same problems and replaced the same things, with equally similar results.
Eventually checked the round wiring multiplug that sits roughly under the inlet manifold and found one wire was bent over and partially broken, this wire was the one that ran from the blue temp sensor to the ECU, hence nothing working right. Replaced the wire (fiddly feckin job) and problem cured, idles at around 1200 when cold, settles to around 800 when warm and no spluttery start.
Only thing is this is on an M20, not sure if the M40 has the same plug............ if you handy with a multimeter you could do a few checks for resistance i guess!
HTH (hope this helps :wink: )
Matt
geo1400
Sat Nov 18, 2006 7:32 pm
Thanks for that information. I was chatting to a mechanic yesterday and he said check the plug that goes into the AFM, clean it up etc. This could be similar thing, i'll trace the wiring from the blue temp sensor as well.
Anyone else have any idea where any dodgy wiring could be?
Sat Nov 18, 2006 11:37 pm
Sounds like an injector is leaking fuel into the manifold while parked, giving an over rich mixture on start up.
When you park the car, stop it by pulling out fuse 11 (fuel pump), and see how it starts after a couple of hours.
It will take longer to start than normal because the fuel rail will be unpressurised, but then, if I'm on the right track, will idle cleanly.
geo1400
Tue Nov 21, 2006 10:40 pm
Ok, given it a couple of days now footering about. Stopped the car by removing fuse 11 and ended leaving it for a day. Started it up and it was great! it actually started quicker and then settled better, just like you said it would Brian!
So after that journey, pulled the fuse again and left it all day. The next start up was a bit of a struggle BUT did settle quicker. The one thing that was still there which is related to a cold engine was when I reved it up, there was a very slight pause/hesitation before the revs increase.
Basically Brian, I thought you'd absolutely nailed it after my first fuse removal because it was sooo much better. But the second time put doubt in my head.
You still think it is a leaking injector?
Cheers again,
Geo1400
autobahn_stormer
Tue Nov 21, 2006 10:48 pm
talking about plugs to the AFM, mine has the large screw in plug to the AFM but also attached to the same mini-loom is another small connector that isnt connected to anything, what does this do!?
Tue Nov 21, 2006 10:50 pm
autobahn_stormer wrote:, what does this do!?
Solenoid valve for charcoal canister, which you don't have, so don't worry about it.
geo1400
Tue Nov 21, 2006 10:52 pm
I've got that as well. I think its used for plugging computers and stuff into. Doesn't do anything as far as i'm concerned, unless someone can tell me it helps to start an M40? :)
Tue Nov 21, 2006 10:54 pm
Probably, but not necessarily the only problem.
geo1400
Brian you were quicker than me there, I now know its nothing to do with computers and stuff! :o:
What do you think about my starting problem? still injectors?
Tue Nov 21, 2006 10:55 pm
Posts are all getting out of order here!
geo1400
Done it again, sorry. You can do a check on injectors can't you? I'm sure I've seen it in Haynes.
geo1400
Fri Nov 24, 2006 9:36 pm
Right, i'm gonna throw something else into the mix, my car generally runs like s**t before the the temp gauge clears the blue bit. After starting poorly it nearly stalls at the biting point and hesitates in low revs?
Any ideas?
Brian if you read this, I haven't taken the injectors apart yet cause I thought I'd narrow down the symptoms, or find more!
geo1400
Sat Nov 25, 2006 9:37 pm
bump
ok this is the last time i'l bump this to the top, i'll just have to live with my dodgy cold start... :cry:
Ant
Retired Team Member
Retired Team Member
Sun Nov 26, 2006 1:29 pm
replace the blue coolant temp sensor and try again dude.
geo1400
Sun Nov 26, 2006 9:57 pm
Hi Ant, I done that! that's the one that sits under the inlet Mani isn't it?
Someone recommended that when I was first having the probs and it didn't solve anything. There were a few fidly plugs under there though, I wonder if i've nor reconnected something properly...
Going mad :mad:
geo1400
Wed Nov 29, 2006 8:55 pm
Right ok. This is it... Someone must have an idea after this...
Decided I would take out my fuel pump relay (which I put in new about 18 months ago), and put my old one back in. And I could not believe it, the car started first turn for 2 days!!
Then for no reason at all, starting the car after work yesteday - back to the same old s**t!!
WHY IS IT DOING THAT?
This is the last time you'll see this post, promise :o:
Martinaston
Wed Nov 29, 2006 9:27 pm
It may sound a daft question but have you checked the oil level ?
and how many miles on the engine ?
There is NO nucleus.
geo1400
Wed Nov 29, 2006 9:30 pm
I check the oil all the time. The cars done 112,000 miles. How could the oil level affect the starting?
Martinaston
Wed Nov 29, 2006 9:46 pm
If you have low oil pressure it won't start, so i was just wondering if you were parking uphill one day and downhill the next. I take it the oil lightbulb's not blown then.
You mentioned that it was serviced so i assume that was a new air filter as well ? take it out if it looks suspect.
It seems odd that it's ok for a few days and then plays up again :? damp days perhaps ? could you lend another ecu to try incase yours has started to rust ?
geo1400
Wed Nov 29, 2006 9:58 pm
Not sure about the oil light :?.
I have suspected the ECU cause I replaced that with a 2nd hand one when I got the car because the original was corroded. And I got a diagnostic done about a year ago and they said there was a fault in the ECU, just couldn't tell me what it was??
What about the fuel pump? I find that quite noisy, but nothing to compare it to.
So many things... :x
Martinaston
Wed Nov 29, 2006 10:04 pm
One step at a time then.
geo1400
Wed Nov 29, 2006 10:07 pm
Yeh i know, problem is i'm bloody knackered cause I've taken so many steps!!
Martinaston
Wed Nov 29, 2006 10:27 pm
Just noticed where you are, so at a guess i'd say go through all the electrics and check for corrosion.
Best of luck, gotta go.
