Posting this up for my mate Darren, some of ye might know a solution to his problem.
He has a 1990 318is which has a niggly problem. He says when he drives it the temp gauge will stay at half way for about 45 mins of driving. Then after that the temp gauge will creep up to between half way and 3/4. It will then stay at this for as long as he drives it. He says theres no oil in water / water in oil and the expansion tank doesn't seem to be generating massive pressure so a head gasket problem seems unlikely???
He says the gauge will also do its little "dancing" trick like alot of E30's and will go from half way to 3/4 back down then up again.
Just wondering if any of ye have any ideas as to what the problem might be??
Thanks!
