Heater valve
Post Sun Nov 12, 2006 1:53 pm
Anyone ever changed one with the matrix in situ?
Ive just been looking at the valve on an air-con matrix (same?) and it looks like a pig of a job :cry:
Post Sun Nov 12, 2006 2:15 pm
Heater valve is dead easy to change. No problems at all, other than avoiding coolant over the inside of your car. (Tip: Disconnect the heater pipes under the bonnet, and flush through with clean water first, and then blow air through).
Second tip: Wrap PVC tape around the valve to hold the little square nuts in place.
This applies to the non air con heater, by the way. Still trying to aquire an aircon one (or two).
Post Sun Nov 12, 2006 4:41 pm
Problem im imagining is this screw, no chance of getting a socket on and not sure theres enough clearance to get it all the way out
This is the air-con matrix, havnt looked at mine closely yet
carlos_320i
Post Sun Nov 12, 2006 4:43 pm
Use a open ended spanner :D
Post Sun Nov 12, 2006 5:06 pm
I would use a spanner carlos but this doesnt look as easy as Brian is explaining!
Im thinking they must be different :?
Post Sun Nov 12, 2006 8:13 pm
This is a bit different than the ones I'm used to, but it doesn't look any more difficult.
The circled bolt looks easily accessible with an open end or ring spanner.
What's on the other end of the circled bolts? The nuts to put the tape on are the square ones on the left side of the picture
Demlotcrew
Post Sun Nov 12, 2006 8:15 pm
i use a wratchet spanner.
Andrew
Post Thu Nov 16, 2006 5:27 pm
It is a different valve, I swaped it for a like one in the end.
Square nuts on the back of the one in the pic Brian, problem is the casing is nearly touching the black pipe of the valve, so you can imagine how much the bolt is covered by it, looks a lot bigger gap in the picture than it actually is
