thanks in advance for any help
will et 20 fit m3
tobias
offered a set of bbs cheapies for winter use but not sure if they will fit
maxfield
yes you may need a 5mm spacer on the front..
tobias
but rears okay???
maxfield
should be fine
tobias
anyone else??? no offence maxfield just wanna get as many opinions as poss
harry_p
et20 are fine, my 16in bbs wheels are 8x16 et20 on the front, 9x16 et24 on the back.
tobias
do you use spacers harry???
harry_p
nope, fit straight on, no rubbing
jpboost
what bbs are they?
et20 is fine, the spacers will only be needed if the spoke style hits your brake calliper.
I've got some 7x16 et20 that fit fine, but I've also got some that need a small (3-5mm) spacer to clear the calliper.
btw you really need to include the other sizes(width and diameter) when quoting offset. i.e. an 8x17 et 20 will be fine, a 10x17 et20 probably wont.
tobias
7x15 et 20
