biting point moving, getting snatchy
bigmattpowell
Post Wed Nov 08, 2006 9:20 am
my clutch generally works fine, biting point normal but if i've had my foot down on it for a long time, the biting point seems to be right at the bottom of travel and snatchy, any ideas appreciated. 318i touring by the way
Steviec
Post Wed Nov 08, 2006 9:31 am
Sounds like the clutch cylinder, mines the same. They are not alot of money from euros/gsf and from what I understand, its an easy job.
<a><IMG></a>
Post Wed Nov 08, 2006 9:34 am
If the clutch fluid level is dropping, it's the slave cylinder(probably). If the fluid level is not dropping, it's the master.
Either way, I recommend you change both at the same time.
bigmattpowell
Post Wed Nov 08, 2006 10:20 am
thanks folks
