how do you add an abs light?
liam012
i would like to add an abs light to my dash, how do you do this as there is no abs light or abs symbol to put a bulb behind?
There should be, the bulb is on a length of wire from the abs ecu
dazleeds
- old skool raver
make sure the bulb goes in the round bit that says abs below it
www.oldskoolfantasy.co.uk
tomtomiS
the abs lamp is the same bulb type as used for ashtray etc and is found on the loom that plugs into the back of the speedo. like daz says it pushes into the dash.
Royalratch
Hello guys.
I'm going to have a go at fitting ABS in the next weeks and have an ABS ready iS (hubs and struts) but have no ABS symbol under my speedo.
Is it the ircle with an ! in it?
If not, do I need a new speedo with an ABS symbol in it?
Cheers.
Cheers.
Royalratch
Just checked - ABS does indeed have it's own dash symbol. Of course it should, wasn't thinking.
Anyone have an ABS equipped speedo?
Promise to set the mileage to my correct original mileage.
tomtomiS
im sure all the binnacles are the same so u should have a hole for the abs bulb holder to fit into. u could shine a torch at the back of the binnacle and u will see the spare telltale symbols. abs is next to the (!) which i think is for auto transmission
ABS light off
ABS light on
Hole for ABS bulb
ABS light on
Hole for ABS bulb
Royalratch
Wow. It really is already there.
Just to be really anal and annoying, I'd still want the ABS symbol in white on there permanent like.
Thanks tho.
Thanks tho.
Tip-ex?
Im sure it would look great
FlashBastd
You won't find an OE cluster with it in white. Mine is a '93 build, so quite late, and doesn't have it in white.
We didn't even know we had ABS until I spotted the pump and replaced the bulb!
1993 E30 318i Lux Auto Touring - SOLD
2001 Ford Mondeo 2.5 Zetec-S 5dr - SOLD
2004 Lexus IS300 Limited Edition Auto - SOLD
2005 Honda CR-V 2.0i Executive Auto
2001 Ford Puma 1.7i Black
Chris-W
tomtomiS
on my clocks the abs light is at the right under the rev counter
