abs light is on
tomtomiS
Post Mon Nov 06, 2006 11:07 am
the abs on my touring is on, im not too concerned about it as the brakes work but it can be annoying so i would like to fix it. not sure whats wrong with it but im assuming the wheel speed sensors should be the first thing to check. are there any other parts that are prone to failure? also my other concern is that while the abs isnt working i wouldnt be able to bleed the brakes properly as the abs pump needs to be bled. or am i barking up the wrong tree, ive spoken to a few bmw techies who say they dont normally bother to bleed the abs pump when changing the brake fluid 8O
dazleeds
old skool raver
old skool raver
Post Mon Nov 06, 2006 11:17 am
9 out of 10 times all it is
is the sensors need a good clean up
Daz
www.oldskoolfantasy.co.uk
tomtomiS
Post Mon Nov 06, 2006 11:27 am
:cool: so it could even be a free fix. would i be able to do it at a jetwash while im doing the chassis or is it a removal job?
dazleeds
old skool raver
old skool raver
Post Mon Nov 06, 2006 11:31 am
when i had my old 325i se
in the history once a year it had been into bmw to have the sensors cleaned due to abs light coming on
dnt think jetwash will do it
you need to take them out and clean them
also clean the much off the hub where the sensor site
may not fix it but as i said majority of the time thats all they need
if that dnt work give b moor a shout im sure he will have some tests you can do to find out whats wrong
tomtomiS
Post Mon Nov 06, 2006 11:33 am
if i was to take the car to a dealer i would hope they could see in the fault memory perhaps that might be an idea.
ac
Post Mon Nov 06, 2006 7:15 pm
Hi dazleeds
Iâ┚¬Ã¢”ž¢m having the same problem as tomtom1. I have cleaned all sensors but the abs light is still on?
baboon5151
Post Mon Nov 06, 2006 7:25 pm
you could have a crack on one the abs ring.
tomtomiS
Post Mon Nov 06, 2006 7:29 pm
what ring is that? the bit the sensor reads from?
gcorky
Boost Junkie
Post Mon Nov 06, 2006 7:39 pm
would a wheel sensor fault trigger abs above a certain speed....this fault is present as system checks itself??
525 sport
baboon5151
Post Mon Nov 06, 2006 8:52 pm
the abs ring is on rear of hub,it has teeth round it.turn wheel full lock with wheel off u,ll be able to see it.if it is cracked you,ll have to replace the full hub.Ԛ£45 from euro parts about Ԛ£90 from dealer.
SGP
Post Mon Nov 06, 2006 9:00 pm
There are four of them to check as well!
If it ain't broke..
Fix it till it is :)
Post Tue Nov 07, 2006 12:42 am
If the ABS light comes on as normal when you start the engine, and then stays on before the car moves, then it isn't the wheel sensors or toothed rings.
tomtomiS
Post Tue Nov 07, 2006 5:48 pm
Brianmoooore wrote:If the ABS light comes on as normal when you start the engine, and then stays on before the car moves, then it isn't the wheel sensors or toothed rings.
so really i should be getting myself to a brake specialist then. i wouldnt have though the likes of kwikfit would be able to, not that my car would ever pass a tyre thru their doors anyway. some place along lines of bexleys or e tech perhaps? i would rather take it to a beemer specialist just i dont know if there's any good ones around my area. anybody got some ideas
matte30
Post Mon Dec 04, 2006 11:54 am
Hi,
sorry for hijacking the post, but I'm having a similar ABS problem. The light comes on almost immediately on start up, regardless of speed, and stays on. Brian, above, seems to think that wouldn't be the sensors or rings - does anyone have an idea of what it might be? Prior to staying on permanently it had been coming on intermittently.
thanks
Matt
Geoff
Post Mon Dec 04, 2006 11:30 pm
Its not unkown for the cables to chaff and split so look for those signs. Then its a quick diagnostic and get yourself down to a eurocarparts or gsf.
stuartgallafant
Post Mon Dec 04, 2006 11:35 pm
tom, are you going to the next guildford meet? on the 13th december? if you are, i'll see if i can pinch the MoDic out of work, and i'll chuck it on the car and do a bit of diagnostics for ya...
