cabriolet leaking
tommype30cab
My cab is leaking at the front of the roof in each corner where the a pillar joins the upright pillar, im not sure why, any ideas would be appreciated. Also the drivers front window doesnt seem to go up as much as i should do, is there any way of adjusting them? ive had the doorcard off today for a look but couldnt see anythin. Please help cos its not fun turning up for work with a wet right leg
. cheers guys
"Racing is life. Anything that happens before or after is just waiting" Steve Mcqueen
Globulator
Mine used to drip too. I greased up the rubber with silicon grease (get it from a plumbers trade counter), a couple of weeks later I noticed that there was no more drip, and there hasn't been since.
Try it, and leave it a couple of weeks before you do anything else. I used to leave towels on the front seats to soak up any drips when I left it too - don't bother now but it might save your seats/floor.
1986 325i 'vert, funk louder than standard.
"No Mr Bond, I expect you to tell me why your 4 litre, 282bhp sports car can't outrun some lardy old Mercs.."
Audio & electronic software: http://www.cutestudio.net
tommype30cab
cheers mate, ill give it a go. i got some black silicone and filled in a few gaps so im hoping that will help aswell, anybody got ant clues about the window adjustment?
Globulator
P.S. Silicon grease will also get rid of those squeaks around the windows as you drive along, just run a bit along all surfaces that touch the glass - including the edges of the glass.
DaveD
- E30Zone Wiki Specialist
orangecurry
make sure you get silicon grease in a tube, NOT silicone spray in a can
you only need a tiny amount.
If this doesn't work, you can buy the complete C-shaped O/E rubber seal for about 60 GBP; quite easy to fit. Goes from one front side window, then across the windscreen, then the other front side window
