JUDDERING like fook
TW166Y
Post Sat Nov 04, 2006 1:42 pm
Right fella's on the mrs 325 e30, when pulling off in 1st there is a judder asthough its coming from the propshaft area up to around 2500 rmp, then you hit second gear and its does the same and so on in every gear.
Instantly i thought it would be the prop, now i have been told it could be the gearbox mounts or even clutch judder as the clutch is slipping like a beeeatch but im fixing that tomorrow.
Just want to know really if anyone has had this problem before, who knows exactly what this judder is because my mrs sh1ts herself every time it does it :D
thanks everyone
Saying goodbye to 4-pot wrongness
Skip
Post Sat Nov 04, 2006 5:16 pm
Flywheel is likely to be scored, especially if the clutch is slipping badly - get a new clutch and have the flywheel skimmed and normal service will resume... :)
ex-325i Touring
dazleeds
old skool raver
old skool raver
Post Sat Nov 04, 2006 5:21 pm
last car i had to do this was betty
but it was deffo prop baring on her
me and lee did spank the poor girl on every drive :evil:
www.oldskoolfantasy.co.uk
TW166Y
Post Sat Nov 04, 2006 8:38 pm
ao what now :cry:
two totally different opinions :cry:
i thought prop originally, obviously if the clutch is slipping im gonna have trouble with the flywheel, so what do i do :roll:
Bob_S
Post Sat Nov 04, 2006 8:40 pm
prop bearing is only Ԛ£25 so change that first easy job then you have eliminated it
Bollocks to this 24v scrap!
TW166Y
Post Sat Nov 04, 2006 8:42 pm
why would the rop go?.......
e went on holiday, clutch was slipping a little, when we were driving around a little in wales suddenly this juddering started...
i think its flywheel problems myself, just cant be sure though :cry:
Post Sat Nov 04, 2006 9:02 pm
Clutch is obviously knackered, so that's the first thing to do.
Prop bearing will get looked at in the process in any case.
Daadji
Post Sat Nov 04, 2006 9:06 pm
Hello, I have just purchased a 325i sport, when driving the temp is fine but when sat it creeps up to 3/4 can anyoone help?
Post Sat Nov 04, 2006 9:20 pm
Daadji wrote:Hello, I have just purchased a 325i sport, when driving the temp is fine but when sat it creeps up to 3/4 can anyoone help?
Welcome to the zone but please repost this as a "new topic".
gareth
Post Sun Nov 05, 2006 10:01 am
it may be that you have a dlutch fluid leak (slave cylinder) that's getting onto the clutch and flywheel. my wifes old E21 320 had this. the clutch started slipping and then juddered like a motherfudger!!!!
TW166Y
Post Mon Nov 06, 2006 11:11 pm
hmmmmm maybe... i propper think it the prop donut myself.. infact im pretty dam sure of it. what would be the best thing to do fella's buy a 2nd decent prop or fit the new bearing? thanks
bigdek
Post Mon Nov 06, 2006 11:20 pm
fit a new bearing but surely if the clutch has been slipping that should be changed asap as well before it goes when u don't expect it
TW166Y
Post Tue Nov 07, 2006 12:56 am
why do they just die like that? i thought they just carried on slipping untill eventually they slip no more but gradually get worse if you get me? didnt get around to fitting it either this weekend cause i was doing my own car for a change :D
SPADGE
Post Tue Nov 07, 2006 1:19 am
TW166Y wrote:why do they just die like that? i thought they just carried on slipping untill eventually they slip no more but gradually get worse if you get me? didnt get around to fitting it either this weekend cause i was doing my own car for a change :D
Clutches do normally wear gradually Twiggy but they can also start to disintegrate when the friction material gets too thin as could be the case here. You could also have contamination on the plate as Gareth suggested. Either way your going to have to get the box out and change the clutch and only then will you know for sure.
