leaking boot 325i tourer
robbo80
Where is it most likely to be coming from .
Many places. Narrow it down a bit.
tomtomiS
check ur lights first, the gaskets perish over time. theres about 6 8mm nuts which u need to undo and the lens just ejects from the rear. also check that when u fill washer bottle it goes into bottle and not down the outside of the pipe and into ur boot area. while ur at it look at the pipework for rear washwipe and make sure it aint fooked
Chris-W
Morat
I get a strange "Leak" whenever I try and use the rear wash wipe... is yours working fine?
(if the water is collecting in the LH cubby I'd check it out).
robbo80
Thaank you guys . rear wiper has seized i think . and rear wash doesent work .
Dan318-is
i jsut changed my rear light seals (coupe, not touring) as everytime i trained there was a huge puddle of water in the corner of each boot. 8.90 from BMW for two gaskets probably worthwhile maintenance as well
Ziggy
That was just your car crying - I can see why it'd be upset if you'd rather use public transport.Dan318-is wrote:everytime i trained there was a huge puddle of water in the corner of each boot
Dan318-is
so its eyes are at the back. and it cries black water? weird!
Split washer pipe where it passes through the hinge.Morat wrote:I get a strange "Leak" whenever I try and use the rear wash wipe... is yours working fine?
Unheard of! Rear washer will only work when the rear wiper is travelling in one directionrobbo80 wrote:Thaank you guys . rear wiper has seized i think .
KDS
You can also get a leak at the upper corners of the hatch. If you've got an old or poorly fitted gasket, rainwater sliding off the roof of the car can pass between the hatch and the gasket and will eventually pool in your spare tire well or side cubbies.
-KDS in Vancouver ('88 325i Touring)
