can u get to fuel tank under rear seat????
tobias
Post Tue Oct 31, 2006 11:38 pm
will be grateful for any help
regards toby
E30Mark
Post Tue Oct 31, 2006 11:41 pm
you can get to the fuel pump & part of the tank, not too sure what your question really is...
PM for details
tobias
Post Tue Oct 31, 2006 11:46 pm
replacing fuel lines to tank and if i cant connect it under seat will have to remove exhaust prop and tthen tank.
tobias
Post Tue Oct 31, 2006 11:47 pm
oh btw its an m3 if that makes a difference???
tobias
Post Wed Nov 01, 2006 12:33 am
E30Mark wrote:you can get to the fuel pump & part of the tank, not too sure what your question really is...
do you gave a better idea now?
E30Mark
Post Wed Nov 01, 2006 8:27 am
I do now!
but I'm sorry i don't know if you can get to all the fuel lines from there, not a job I've ever had to do.
PM for details
Demlotcrew
Post Wed Nov 01, 2006 9:10 am
It would help if you told us what pipes?
Andrew
jpboost
Post Wed Nov 01, 2006 10:54 am
I replaced the static pipes on my m3 without touching the tank/exhaust.
You only need to drop the tank if you are changing the rubber hoses that run over the top of it, and these are very rarely a problem. Your other threads seemed to be referring to the solid fuel lines. Have you actually looked under the car? It's fairly easy to see how it all comes apart.
tobias
Post Wed Nov 01, 2006 1:38 pm
yes its the solid fuel lines. gonna be replacing all four of them but one goes up side of tank so cant quite see how far although new lines arriving from bmw today so should have better idea
tobias
Post Wed Nov 01, 2006 1:41 pm
they are all around about 2 metres in length and are pre pormed. 2 lead to the filter other 2 to the tank
