Problem with headlight
martinclan
Post Sun Oct 29, 2006 6:44 pm
My offside dipped beam unit (on the 318is) seems to be coming unseated from the lower mounting point resulting in it pointing up a bit more than it should be! If you press at the bottom it it seems to pop back in until you get the next big bump!!
Is this a common problem? Do I need to replace the whole headlamp assembly?
Robin
It's an E30 Jim but not as we know it...
zaust
Zone day release
Post Sun Oct 29, 2006 7:12 pm
A small plastic push stud. easy fix.. (or Supa glue but dont tell...)
M30 Tech 1 Touring on gas.
