had abit of a search, and it seems the 2 most common problems are the center prop bearing, and the rear topmounts.
now the fact that it kind of goes away when coasting points towards prop bearing as opposed to topmount, but placing my hand behind the rear ashtray on the transmission tunnel, the knocking doesnt feel very 'close' if you get my meaning.
and with the topmount, it dont start it after ive been going over a bump or anything like that, i was driving up a perfectly straight dually today and it started doing it. surely if the topmount was buggered, it would be more likly to start knocking when you go over a bump..? which it does not..?
so any ideas? i was also thinking maybe its the exhaust hitting off something.
as its pissing it down with rain, i havnt had a chance to get under and have a proper look at it, so im hoping with the info ive provided one of you guys can give me a definite/pretty damn sure, answer to the situation
cheers
craig
