Quick wheel size Q 16x9 et15
appletree
Can any one tell me if 16"X9" et15 wheels with stretched 205 rubber will fit on a e30 ok? cars not lowered from standard but it is an IS sowill be on m-tech stuff
dazleeds
- old skool raver
im pretty sure youll need 215s and they will be stretched too
dnt think 205s would stretch that far and still be safe fella
i know twiggy had to get 215s for his borbets
ps i have 7.5x16s and have 225s on the rear with no trouble at all and my cars pretty lowww
www.oldskoolfantasy.co.uk
ste
What offset? You may be very, very lucky with exactly the right offset, but I reckon any offset with a 9 might cause issues.
If it's not lowered it will look stupid. If you lower it you'll have to get Ԛ£1k+ ready to spend on arches.
ste
205s will go on a 9" rim nicely.dazleeds wrote: dnt think 205s would stretch that far and still be safe fella
dazleeds
- old skool raver
i stand correctedste wrote:205s will go on a 9" rim nicely.dazleeds wrote: dnt think 205s would stretch that far and still be safe fella
however ive just seen the pics of 9inchers with 205s and fook me they are stretched
im just thinking of how bad our roads are i wouldnt feel safe with them stretched like that
ste
Stretched like a new inmate in the showers.
ste
I think these are 195/40/16s on a 9"...
dazleeds
- old skool raver
now thats taking the pissste wrote:I think these are 195/40/16s on a 9"...![]()
Steviec
Ive got 16x9 wheels on the cab with 205/40/16 tyres, but I cant go any wider on the front otherwise the tread will protrude out of the arch making them illegal.
If and when I get round to chanding the tyres though, I would go for a bigger sidewall, like 205/50/16, that way it will fill the arch better and wont put so much force on the sidewall.
Ill try to dig out a pic later, I cant view any pics while at work.
<a><IMG></a>
appletree
but do theyfit with out rubbing stevic?? its an IS so its on the m-tech stuff which is slightly lower anyway -25 on standard???? looking at the borbet bs in the forsale section! i realy realy like these and am very tempted if they would fit the car with out Ԛ£Ã”šÃ‚£Ãƒ”šÃ‚£ spent on the arches. any one know if you can get borbet b's in a 15" or smaller width 8" say?
maxfield
I'm sure twiggy fitted them on -35mm and din't have any problems but i'm sure he'll be here to confirm later
Steviec
My car is lowered 60mm and the only time they rub is on quite alot of lock on uneven ground, and that is just against the suspension strut (outer sleeve). Even when I hit those big dips on the motorway they dont rub, and ive got 2 15" subs in the boot.
<a><IMG></a>
appletree
Cheers steviec, do you know what offset your are then? have you still got your arche liners in? from the pics it looks like you have.
benjy
I'd be carefull how far you stretch tryes on wide rims.......mine are 9x16 with 215/40 16 toyos and there aint much grip in the wet, makes corners real fun!!!!!
Gaffa tape is like "the force" - it has a light side, a dark side, and it holds the universe together.
There's nothing that shouts "Poor Workmanship" more than wrinkles in the Gaffer tap
Steviec
I think the offset is 35 but ive got 15mm spacers on the front, an offset of 15 should give all the clearance needed.
Yes I do still have the arch lines, and I have had no arch work done.
<a><IMG></a>
d6dph
Steviec
Thanks, I knew there were some better pics somewhere!
<a><IMG></a>
d6dph
No probs fella.
